My FTTH using Huawei ONU. I’ve swap the ONU to the new on and the serial number is difference.
Later, I’ve configured LOID/ONT Authentication to be the same then it registered and worked but they are done through ONU web management
My question is. Can we configure OLID or OLT authentication on SFP/GPON Interface similar to previous web GUI?
I’ve expected if I could configured this parameter. The Mirktok SFP-GPON should work with my FTTH as it seem my ISP didn’t use H/W serial number for registration.
Thanks!
