You should use similar SFP modules on both ends of optical link. These modules are very different, S+85DLC03D is 10Gbps 850nm multi mode, S-31DLC20D is 1.25Gbps 1310nm single mode.
This is an old question about whether a SFP module can work on the SFP+ port. The answer is “in most cases, SFP Can be Plugged into SFP+ Ports”, but you have to configure the interface before inserting the SFP. Sometimes you have to tell the switch/router vendors that the port is going to run at 1000 megabit before you insert the SFP..
