I’ve got a couple of CRS226-24G-2S+RM Routers/Switches with which I’m trying to use MikroTik S-85DLC05D Transceivers.
According to the documentation, these should work in the SFP+1 cages.
I can install Mikro-Tik S-85DLC03D Transceivers in these two routers, in the SFP+1 cages, connect a short cable between these two 10Gb transceivers, and the two routers link up just fine.
But, if I try the same thing with the 1.25Gb transceivers, I can’t get a reliable link between the two routers.
Has anyone else had any trouble in getting 1.25Gb SFP transceivers to work in the SFP+1 port on the CRS226-24G-2S+RM router?
John Rayfield, Jr.
