As subject, purchased 2 SFP modules from mikrotik distributor, neither work in 2011UAS-RM using 5.23 and 6.0rc9, but they are detected in our CCR1036-12G-4S, from the CCR:
[admin@MikroTik] > /interface ethernet monitor sfp3
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
sfp-module-present: yes
sfp-rx-lose: no
sfp-tx-fault: no
sfp-connector-type: LC
sfp-link-length-50um: 550m
sfp-link-length-62um: 270m
sfp-vendor-name: OEM
sfp-vendor-part-number: GLC-SX-MM-C
sfp-vendor-revision: A1
sfp-vendor-serial: TC1412180046
sfp-manufacturing-date: 12-12-18
sfp-wavelength: 850nm
Also tried another sfp module which also works in CCR but not in 2011UAS-RM
sfp-vendor-name: EDIMAX
sfp-vendor-part-number: MG-1000AMA
sfp-vendor-revision: 0000
sfp-vendor-serial: C416011856
How do I get these working?
I would think you should work this through your distributor. They should be selling and supporting compatible modules if they are selling both RouterBoards and SFPs.
Dobby
February 7, 2013, 4:16pm
3
Deleted because not related.
Turns out these modules work fine, the problem was auto negotiation on the CCR defaults to off and needed to be turned on (thanks Chaos @ linitx).
nest
March 20, 2013, 2:30pm
5
This has been acknowledged by MT as something that will be fixed in the next release.
gilito
February 7, 2021, 12:24pm
6
Hi!
The same with 35LC20D and 53LC20D pair.
I tested with an RJ45 SFP and port works. So I think is about firm/soft issue
On RB3011 I can se module present, led on and how version an tx/rx power
On Rb2011 unable to see nothing
Routerboard info
/system routerboard> print
;;; Firmware upgraded successfully, please reboot for changes to take effect!
routerboard: yes
model: 2011UAS
serial-number: 374802D1AEF8
firmware-type: ar9344
factory-firmware: 3.0rc5
current-firmware: 6.45.3
upgrade-firmware: 6.48
SFP monitor
/interface ethernet> monitor sfp1
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-rx-loss: yes
sfp-type: (unknown)
eeprom-checksum: good
eeprom: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
Resources info
/interface ethernet> /system resource print
uptime: 1w5h1m1s
version: 6.48 (stable)
build-time: Dec/22/2020 11:20:49
free-memory: 92.5MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 10%
free-hdd-space: 104.3MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 678175
write-sect-total: 70360738
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB2011UAS
platform: MikroTik
If needed more info or screnshots, I can do!
Your 2011 might actually be too old.
I had a really old 2011 at a time that didn’t take my SFP’s. Support said that there was some revisions of the board, and that the really old ones didnt work correctly with some or all SFP’s.
