I’m trying to install 2 MAXXWAVE SFP modules on the CCR1009-8G-1S-1S+ but only the SFP port works
On the SFP+ port the module shows up, but it does not transmit so the other side shows no-link
[jfrater@CRIX] /interface ethernet> monitor 8
status: link-ok
auto-negotiation: done
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-lose: no
sfp-tx-fault: no
sfp-connector-type: LC
sfp-link-length-9um: 20000m
sfp-vendor-name: MAXXWAVE
sfp-vendor-part-number: MW-LX-SM-US
sfp-vendor-revision: A
sfp-vendor-serial: CLS10300545
sfp-manufacturing-date: 14-05-09
sfp-wavelength: 1310nm
sfp-temperature: 46C
sfp-supply-voltage: 3.348V
sfp-tx-bias-current: 29mA
sfp-tx-power: -6dBm
sfp-rx-power: -6dBm
Is this a know issue? Is this hardware related? Is it software ralated?
