I’m sure this is captured somewhere, but I can’t find it … ![]()
What (maximum) speed of SPF does the RB260GS support?
Thanks!
Thanks!
I don’t see much in the spec sheet, but based on the switch datasheet, and the compatible SFP’s noted … looks like 1 Gb/s, right?
Typically the SFP won’t limit performance as much as the active device (switch) and SI of the PCB.
Thanks!
