having already read other posts about SFP modules on CRS like the following
I just wanted to share another experiences on CRS326-24G-2S+ (currently RouterOS v7.7) with copper SFP RJ45 modules, maybe someone finds it interesting.
Ordered the S+RJ10 module from Mikrotik and hope that this will work, will report experiences here.
The following modules mentioned here work fine with other devices but sadly none of them seem to work on the CRS.
Even when auto-negotiation disabled and you manually set a specific speed they still do not work.
HP 1Gb SFP RJ-45 Module - Spares PN: 453156-001 - Type: copper - Speed: 1000M
> /interface/ethernet/monitor sfp-sfpplus2
status: no-link
auto-negotiation: failed
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-link-length-copper-active-om4: 100m
sfp-vendor-name: FINISAR CORP.
sfp-vendor-part-number: FCLF-8521-3-HP
sfp-vendor-revision: A
sfp-vendor-serial: PJR4XV8
sfp-manufacturing-date: 10121851
eeprom-checksum: good
eeprom: 0000: 03 04 00 00 00 00 08 00 00 00 00 01 0c 00 00 00 ........ ........
0010: 00 00 64 00 46 49 4e 49 53 41 52 20 43 4f 52 50 ..d.FINI SAR CORP
0020: 2e 20 20 20 00 00 90 65 46 43 4c 46 2d 38 35 32 . ...e FCLF-852
0030: 31 2d 33 2d 48 50 20 20 41 20 20 20 00 00 00 81 1-3-HP A ....
0040: 00 10 00 00 50 4a 52 34 58 56 38 20 20 20 20 20 ....PJR4 XV8
0050: 20 20 20 20 31 30 31 32 31 38 35 31 00 00 00 c9 1012 1851....
0060: 00 00 00 d0 00 81 45 01 34 35 33 31 35 36 2d 30 ......E. 453156-0
0070: 30 31 20 20 20 20 00 00 1d af e9 86 17 9f 6f f6 01 .. ......o.
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
Foundry E1MG-TX - Type: copper - Speed: 1000M
status: no-link
advertising:
sfp-rx-loss: yes
sfp-tx-fault: no
sfp-vendor-name: FOUNDRY NETWORKS
sfp-vendor-part-number: DM7041-FN-C
sfp-vendor-revision: C
sfp-vendor-serial: 00015553
sfp-manufacturing-date: 07040201
sfp-wavelength: 16653.93nm
sfp-dwdm-channel-spacing: 1Ghz
eeprom: 0000: 03 04 00 00 00 00 08 00 00 00 00 01 0d 00 00 00 ........ ........
0010: 00 00 64 00 46 4f 55 4e 44 52 59 20 4e 45 54 57 ..d.FOUN DRY NETW
0020: 4f 52 4b 53 01 00 00 00 44 4d 37 30 34 31 2d 46 ORKS.... DM7041-F
0030: 4e 2d 43 20 20 20 20 20 43 20 20 20 41 0c c1 25 N-C C A..%
0040: 00 00 00 00 20 20 20 20 20 20 20 20 30 30 30 31 .... 0001
0050: 35 35 35 33 30 37 30 34 30 32 30 31 00 00 00 21 55530704 0201...!
0060: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........ ........
Ubiquiti UF-RJ45-1G - Type: copper - Speed: 10/100/1000M
status: no-link
advertising:
sfp-rx-loss: yes
sfp-tx-fault: no
sfp-vendor-name: UBNT
sfp-vendor-part-number: UF-RJ45-1G
sfp-vendor-revision: 1.0
sfp-vendor-serial: X20092800327
sfp-manufacturing-date: 20-08-18
0010: 00 00 64 00 55 42 4e 54 20 20 20 20 20 20 20 20 ..d.UBNT
0020: 20 20 20 20 00 00 00 00 55 46 2d 52 4a 34 35 2d .... UF-RJ45-
0030: 31 47 20 20 20 20 20 20 31 2e 30 20 00 00 00 1b 1G 1.0 ....
0040: 00 00 00 00 58 32 30 30 39 32 38 30 30 33 32 37 ....X200 92800327
0050: 20 20 20 20 32 30 30 38 31 38 20 20 00 00 00 7c 2008 18 ...|
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
Kind regards!
