SFP+ Multimode module recommandation
Dear MK enthusiasts,
I need your help to find the best hardware SFP+ module to transport 2x10Gbps on a CCR1072 on a 400m long multimode fiber.
I have allready test this link between two CRS226 with S+85DLC03D. Link is UP, but I have lost 2 times the link on a 48h period.
Do you know if there is a compatible multimode “long range” SFP+ ?
Thanks a lot
A.
That is extreme range for 10G mm.
Yeah, I know :frowning: :frowning:
That’s why I ask, perhaps someone has an awesome trick to achieve this link withtout errors :slight_smile:
A.
You “can” try to use single mode SFP’s. Although not meant for it, it “might” work.
But achieving 10 G is hard.
Maybe you can think in using Cisco or HP SFP’s. Mikrotik does not limit in vendor (as far as I know, I tested Ericsson, HP and Finistar). No problem.
