SFP pci cards for Fibre modules
Hey guys,
I’m looking for a Mikrotik solution that can run with SFP’s and/or fibre ports.
I know that the PowerRouter’s apparently support this and someone also recommended an SFP PCI Card over here
http://forum.mikrotik.com/t/which-brand-fiber-lancard-1000basedlx-is-supported-by-mt3-23/28350/1
The card recommended was: http://www.hotlavasystems.com/6FGNICe.php
However I was wondering what the Mikrotik actually shows up when these are connected?
Do they display as a Gb ethernet interface or does Fibre have its own tab etc?
Is there anyone who is using these at the moment that would be able to link a winbox or terminal image showing the recognized interfaces.
if it’s supported - it will be seen as usual ethernet adapter
