SFP port status
Hello
I need to get information about sfp-tx-power and sfp-rx-power and put this in scritpt to send email and sms.
I need help, same basic script to get information from SFP module.
/interface ethernet monitor sfp1
Output:
# aug/24/2017 21:19:35 by RouterOS 6.40.1
                    status: link-ok
          auto-negotiation: done
                      rate: 1Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: LC
       sfp-link-length-9um: 10000m
      sfp-link-length-50um: 550m
      sfp-link-length-62um: 550m
           sfp-vendor-name: SumitomoElectric
    sfp-vendor-part-number: SCP6G44-H2-BWE
       sfp-vendor-revision: A
         sfp-vendor-serial: 01T4xxxxxxx
    sfp-manufacturing-date: 10-01-12
            sfp-wavelength: 1310nm
           sfp-temperature: 47C
        sfp-supply-voltage: 3.311V
       sfp-tx-bias-current: 6mA
              sfp-tx-power: -6.942dBm
              sfp-rx-power: -18.987dBm
           eeprom-checksum: good
This works ok, but i need only TX and RX power on SFP modules and set it to global value and next use in other scripts.
Thanks for Help
Marcin
Well, you can simple use variables
:global monitor [/interface ethernet monitor sfp1 once as-value]
:put ($monitor->valuewhatyouwant)
Hello
Not work, return:
.id=*7;advertising=;auto-negotiation=done;comment=;eeprom=0000: 03 04 07 00 00 00 02 12  00 01 01 01 0d 00 0a 64  ........ .......d
0010: 37 37 00 00 53 75 6d 69  74 6f 6d 6f 45 6c 65 63  77..Sumi tomoElec
0020: 74 72 69 63 00 00 00 5f  53 43 50 36 47 34 34 2d  tric..._ SCP6G44-
0030: 48 32 2d 42 57 45 20 20  41 20 20 20 05 1e 00 76  H2-BWE   A   ...v
0040: 00 1a 00 00 30 31 54 34  30 36 36 30 37 33 36 39  ....01T4 06607369
0050: 20 20 20 20 31 30 30 31  31 32 20 20 58 f0 01 d6      1001 12  X...
0060: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
0070: 20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20
0080: 69 00 d3 00 5f 00 d3 00  9c 40 6d 60 8c a0 75 30  i..._... .@m`..u0
0090: 75 30 00 00 61 a8 00 00  27 10 02 76 13 93 04 ea  u0..a... '..v....
00a0: 13 94 00 7e 13 94 00 7e  00 00 00 00 00 00 00 00  ...~...~ ........
00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00  ....?... ........
00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 e6  ........ ........
00e0: 30 32 81 ce 0a ff 07 e6  07 31 00 00 00 00 00 00  02...... .1......
00f0: 00 40 00 00 00 40 00 00  00 00 00 00 00 00 00 00  .@...@.. ........;eeprom-checksum=good;full-duplex=true;link-partner-advertising=;name=sfp1;rate=1Gbps;rx-flow-control=false;sfp-connector-type=LC;sfp-link-length-50um=550;sfp-link-length-62um=550;sfp-link-length-9um=10000;sfp-manufacturing-date=10-01-12;sfp-module-present=true;sfp-rx-loss=false;sfp-rx-power=-8615;sfp-supply-voltage=3323;sfp-temperature=48;sfp-tx-bias-current=5;sfp-tx-power=-6942;sfp-type=SFP-or-SFP+;sfp-vendor-name=SumitomoElectric;sfp-vendor-part-number=SCP6G44-H2-BWE;sfp-vendor-revision=A;sfp-vendor-serial=01T406607369;sfp-wavelength=131000;status=link-ok;tx-flow-control=false
Other solution:
I can save a dump to a file, but how do I read a selected data (sfp-tx-power and sfp-rx-power) from a file and send it to value?
Anybody help?
As i wrote use variables and print specific key.
:put ($monitor->"sfp-tx-power")
:put ($monitor->"sfp-rx-power")
I think mikrotik dont support this, just use my solution and write it to /tool sms script or other script, if you are interested to scripting i recommend mikrotik wiki
Your solution displays too much unnecessary information. For me not work. I don’t believe that Mikrotik can’t do that…
This Script working OK.
:global monitorsfprx [/interface ethernet monitor sfp1 once as-value]
:global monitorsfprx [:put ($monitorsfprx->"sfp-rx-power")]
and
:global monitorsfptx [/interface ethernet monitor sfp1 once as-value]
:global monitorsfptx [:put ($monitorsfprx->"sfp-tx-power")]
Is there a way to monitor the SFP modules temperature via such a command line on a crs309 in router mode ?
works ok ros 6.48.3 on CRS317
Thank You
Thank You
:put is for interactive terminal,
use :put inside any type of script is an idiocy error.
:global monitorsfptx ([/interface ethernet monitor sfp1 once as-value]->"sfp-tx-power")
:global monitorsfprx ([/interface ethernet monitor sfp1 once as-value]->"sfp-rx-power")
# but this is better: prevent error when sfp1 is not connected or SFP models that not support read power are used
:global monitorsfp1 [/interface ethernet monitor sfp1 once as-value]
:global monitorsfp1tx ([:tonum ($monitorsfp1->"sfp-tx-power")]+0)
:global monitorsfp1rx ([:tonum ($monitorsfp1->"sfp-rx-power")]+0)
