SFP+ transceiver for CCR1036-8G-2S+ ?
We have supermicro server with Intel 82599 based 10Gbits NIC. Will Mikrotik S+85DLC03D transceiver will work with Intel 82599 based NIC and Mikrotik CCR1036-8G-2S+?
For x520 series adapters they had module restrictions in place, so that you could use only their SFP+ transceivers in these cards. So I suggest to check with their documentation first. However on CCR+ side you can use our S+85DLC03D transceiver.
Thank you krisjanis,
already ordered two S+85DLC03D transceivers for CCR side,
for Intel side I have found cheap alternative here
Hi there.
I’m looking for 1 fiber wdm (SC or LC connector) sfp+ module compatible with ccr1036-8g-2s+ but oem S+31DLC10D, which needs 2 fiber LC.
Did anyone tested non-original 10G modules?
Maybe Support guys can help with?
Thanks.
Jus today tested some few cisco and few tbase spf. On windows adapter show that they see inserted spf module but link stays down. Looking for intel spf
