It’s been a while since the last upgrade and I’ve skipped some versions, so forgive me if I missed something in the announcements.
I’ve been using scp to copy over backups from Mikrotik to the host machine on a daily basis. After the upgrade it stopped working with the following error:
exec request failed on channel 0
which after some googling revealed that sftp server might be missing.
Were there any changes in the latest build that might have affected sftp? I’ve got 2 routers with different configs, both give the same error when trying to scp files from them.
I may have a similar issue. I have backups copied by ftp(not sftp) each week. Today’s ftp job failed for all routers v6.34 and above. Routers below v6.34 still work. My backup utility(Cobian Backup) says:
2016-02-12 15:15 The user “ftp” has initiated a session on “1.2.3.4:21”
2016-02-12 15:15 The remote directory has been changed to “/”
2016-02-12 15:15 Downloading the remote directory “/” to “C:\Users\tempuser\AppData\Local\Temp\Root directory”
ERR 2016-02-12 15:15 Couldn’t get the remote directory list: ‘LIST’: not enough permissions
When I try to ftp with a command line in Windows, I get similar:
C:\Users\tempuser>ftp
ftp> open 1.2.3.4
Connected to 1.2.3.4.
220 Mikrotik FTP server (MikroTik 6.34.1) ready
User (1.2.3.4:(none)): ftp
331 Password required for ftp
Password:
230 User ftp logged in
ftp> get log.0.txt
200 PORT command successful
550 ‘RETR’: not enough permissions
ftp>
Looking at the v6.34 changelog, maybe it’s this?
ssh, ftp - make read, write user group policy aware
You found the answer. If your ftp or ssh user belongs to group with just ftp/ssh policy, it won’t be able to do anything useful. Add read and write as needed and problem solved. Also sensitive seems to be required if you want to access *.backup.
Read policy was what was required. I would assume the write policy would be required if I wanted to use ftp put command, but I am only getting backups.
My mistake. I had already set up the group with ftp and sensitive policy. I thought I had enabled all policies for the group the user belongs to during my testing to confirm the permissions issue, but I must have missed something.
So, as of 6.34, read and/or write policy is now also required.
