Recently upgraded all my units (RB1100 & 3x hAP AC) from 6.37 to 6.38. After the upgrade I noticed some slowness, so I started to troubleshoot. Noticed that no 5Ghz radios were advertising the use of more than on chain . Eventually, I ended up fixing the issue by recreating my CapsMan profile and all underlying object dependencies (security, datapath, channel, etc). I assume somehow, with the upgrade the chain value might have become corrupt. Anyways…
With all this troubleshooting, I noticed that even thought I’m using “any” in the “Guard Interval” setting in my CapsMan profiles, I’m unable to see any Clients associate using SGI. This is true for both AC 5Ghz and N 2.4Ghz wireless. Is this a limitation of CapsMan? or am I missing something?
Have also seen this and posted a while back, anyway got no response. My scenarios are below, and in none of them clients connect with SGI (makes no difference to leave SGI unchecked or marked as “all” on the CAPsMAN configuration).
CAPsMAN (6.36.4): RB2011UiAS-2HnD
CAPs (6.36.4 or 6.37.3): wAP, mAP-2n, RB952, RB941 and RB2011UiAS-2HnD (CAPsMAN and CAP).
Recently replaced the RB2011 with a hEXr3 (on 6.38), to no effect, nobody connects using SGI while CAP mode is enabled, although disabling it and creating the interfaces on the routers makes SGI work flawlessly.
i can confirm this issue with capsman on 6.37.1, in fact i have disabled capsman because this and the group key update setting absence (Supposedly fixed on 6.38 i have not tried)
I didn’t get to test the group key timeout setting as I rolled back, but I did notice it’s not exposed via the Winbox GUI; nor was the online manual updated to show it’s existence. However, the “group-key-update” setting is now available under the “capsman → security” object:
/caps-man security> add
Creates new item with specified property values.
authentication-types --
comment -- Short description of the item
copy-from -- Item number
eap-methods --
eap-radius-accounting --
encryption --
group-encryption --
group-key-update --
name --
passphrase --
tls-certificate --
tls-mode --
@chechito - When modifying this setting, what have you found to work best with iOS devices?
i dont know, i droped capsman long time ago because of the absence of data-rate/MCS configuration, i give capsman a try on 6.37.1 because data-rate/MCS configuration was added and i want to test it but knock with sgi and group key interval issue just to drop capsman again.
I dont understand why its so difficult to just synchronize all the wireless existent settings on capsman
We have seen “synchronisation” issues with the “Client to Client Forwarding” option between CAPSMAN and the CAP’s. e.g. using the default option in CAPSMAN which should be “enabled”, we found some CAP’s would not allow forwarding between clients. We changed the setting to “enabled” on CAPSMAN and re-provisioned the affected CAP’s and clients were then able to forward to each other.
So it seems the sync problem is wider than just this one setting
