Hello
If I have a like that can pull 1000Kbps Max (actual througput) do you guy find you need to set your shaper Max to about 900K for it to be affective?
Hello
Yes if it is a shared connection or if the tech used can vary the speed. Be aware that you have limited ability to shape inbound traffic on an interface. You can really only queue outbound traffic on an interface.
