I have DSL line. Via this line I use this connection:
2x IP tunel
L2TP connection
PPTP connection
I need use shaping for this services (for example):
I don’t know, how I mark packets for this services. I need set services as independe on connection, because, all connection using DSL line.
… I need shape RDP (3389) as high priority service for L2TP, PPTP users and for IP Tunels users.
How I must set QTrees? I read more items in this forum, but I still don’t set it.
Mitak
June 12, 2006, 7:36am
2
Mark HTTP packets:
/ip firewall mangle
add chain=prerouting protocol=tcp dst-port=80 action=mark-connection new-connection-mark=http passthrough=yes
add chain=prerouting connection-mark=http action=mark-packet new-packet-mark=http_p passthrough=yes
Mark SMTP packets:
add chain=prerouting protocol=tcp dst-port=25 action=mark-connection new-connection-mark=smtp passthrough=yes
add chain=prerouting connection-mark=smtp action=mark-packet new-packet-mark=smtp_p passthrough=yes
Mark RDP packets:
add chain=prerouting protocol=rdp dst-port=3389 action=mark-connection new-connection-mark=rdp passthrough=yes
add chain=prerouting connection-mark=rdp action=mark-packet new-packet-mark=rdp_p passthrough=yes
Add the queue types:
/queue type
http queue, limited to 512k:
add name=“http” kind=pcq pcq-rate=512000 pcq-limit=100 pcq-classifier=dst-port pcq-total-limit=2000
smtp queue,limuted to 256k:
add name=“smtp” kind=pcq pcq-rate=256000 pcq-limit=100 pcq-classifier=dst-port pcq-total-limit=2000
rdp queue, limited to 1Mbit:
add name=“rdp” kind=pcq pcq-rate=1024000 pcq-limit=100 pcq-classifier=dst-port pcq-total-limit=2000
set the queue tree:
/queue tree
add name=shaper parent=DSL
add name=q_rdp parent=shaper packet-mark=rdp_p queue=rdp priority=7
add name=q_http parent=shaper packet-mark=http_p queue=http priority=8
add name q_smtp parent=shaper packet-mark=smtp_p queue smtp priority=8
where DSL is the name of your DSL out interface.
cmit
June 12, 2006, 7:41am
3
The queue types names are all “http” here (copy and paste ) - beware to adjust them to rdp/smtp/http respectively…
Best regards,
Christian Meis
OK It’s work, but I have second problem with this solution
I use (shaping) FTP →
client from LAN to WAN a need limit 1500Kbs
client from WAN to LAN a need limit 512Kbs
=> DLS line type
Thanks for help.
in the manual and for the same task they said FORWARD , here its PREROUTING , wich one is the correct choice and why ??? i asked this question for 1000 times here and … i found its the hardest question ever asked ..
Mitak
June 14, 2006, 9:09pm
7
I will answer you tomorow… tonight (its 00:08 now) im drunk, it`s possibly to do nonsenses… some hours of sleeping will be a good relax for me.
I should drink ! It miss me
Mitak
June 15, 2006, 6:54am
9
You want to shape only FTP connections ftom WAN to LAN & LAN to WAN, or all connections?
I need shape all connection by protocol:
download (on local) to 1500k
upload (on side wan from my LAN ) to 512K
When I connect (for example FTP) from WAN and “download” from my LAN server a use limit DSL 512,
but when i connect from LAN PC to some public FTP i need limitation 1500K - DSL limitation.
QTree using UP limit and get resouces (bandwidth) from this limit.
I don’t know how I must set it.
Thanks !!!
Mitak
June 15, 2006, 7:04am
11
See this wiki for an example:
http://wiki.mikrotik.com/wiki/PCQ_Examples
I think this will help you. If not, just post here again
