Share hotspot users between different routerboards
Hello guys ,
Is there any way to share hotspot users and their bandwidth usage between two different router-boards .
Example of the required solution :
  • I have two router-boards (750gl , RB2011UiAS) and currently I use RB2011UiAS to load balance between 9 local loops and this is the maximum number of local loops to be load balanced on this router-board , I need to increase the bandwidth and add extra local loops so I decided to use the unused router-board 750gl but I need to share the users activity (roaming) within the two devices as the same users will use the two devices to go through internet .
  • I need to build this solution as every user is limited with certain quota and I need to use this type of roaming to give every user the predefined quota whatever he use which device to go through internet .
Important Note : Every router-board will be in a different physical location due to local loops limitation .
Thanks in advance
