Share printer with two networks
We have two networks running from an RB1100AH router:
  1. 192.168.1.0/24 (interface ether2)
  2. 192.168.0.0/24 (interface ether10)
I’d like to print to an HP P2055dn printer at 192.168.1.100 (static IP) from the second network on ether10.
Here’s what I’ve done with the firewall:
add chain=forward comment="hp printer access" dst-address=192.168.1.100 in-interface=ether10 \
out-interface=ether2 src-address=192.168.0.0/24
add chain=forward comment="hp printer access" connection-state=established dst-address=\
192.168.0.0/24 in-interface=ether2 out-interface=ether10 src-address=192.168.1.100
From the second network (192.168.0.0/24), I’m able to ping the printer but not print to it. What am I missing?
Thank you.
Sounds like routing problem. Don’t need rules to accomplish this, maybe masquerade rule with ether 2 as out interface, because most printers can only set gateway. Create route in pc using 192.168.0.0/24 (actual ip of router) as gateway for destination ip 192.168.1.0/24.
Ah, the solution was easy enough once I re-checked my firewall rules. I had a rule above the ones I was adding that dropped everything that wasn’t from a specific MAC address.
So for anyone trying to share a printer across two networks running under a single Mikrotik, you can simply use firewall rules, substituting your network information:
chain=forward action=accept connection-state=new
src-address=192.168.0.0/24 dst-address=192.168.1.100
in-interface=ether10 out-interface=ether2
chain=forward action=accept connection-state=established
src-address=192.168.1.100 dst-address=192.168.0.0/24 in-interface=ether2
