share wifi for mobile
Hello friend i have RB SXT 5HPnD r2 how to configure to share wifi for mobile
SXT 5 is a low cost, high transmit power 5GHz outdoor wireless device. SXT 5 can be used for point to point links or as a CPE for point to multipoint installations.
Think you are better of with an accesspoint:
https://mikrotik.com/products/group/wireless-for-home-and-office
i want it for mobile can i use it or not ?
The SXT 5 is HIGHLY directional (or if you prefer it receives and transmits in a narrow angle, different models of SXT 5 have either 28° or 90°, as opposed to normal AP’s that are usually omnidirectional, i.e. 360°), hence the PtP (Point to Point) or PtMP (Point to Multipoint) suggested usage.
So if your mobile client is not very mobile and tends to stay always in the same place or move only in a given confined area, of course it can do.
so can you tell me the configuration of SXT for mobile
