Hi
I have a HAP AC that is running with a shared SSID.
When I look in registrations I can see everything is using WLAN1 which is the 2.4GHz band and nothing is going onto the 5GHz.
If i rename the 5GHz band to a different SSID my devices can connect to it no problem, is there a reason everything seems to be going for the 2.4GHz band or somewhere I could look to try to figure out why ?
My config looks like this:
[admin@MikroTik] > interface wireless print
0 R name="wlan1" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:1
interface-type=Atheros AR9300 mode=ap-bridge ssid="proa
frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-C
scan-list=default wireless-protocol=802.11 vlan-mode=no
wds-mode=disabled wds-default-bridge=none wds-ignore-ss
bridge-mode=enabled default-authentication=yes default-
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ss
security-profile=proactive compression=no
1 name="wlan2" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:1
interface-type=Atheros AR9888 mode=ap-bridge ssid="proa
frequency=auto band=5ghz-a/n/ac channel-width=20/40mhz-
bridge-mode=enabled default-authentication=no default-f
2 name="wlan3" mtu=1500 l2mtu=1600 mac-address=6E:3B:6B:1
interface-type=virtual master-interface=wlan1 mode=ap-b
ssid="hotspot" vlan-mode=no-tag vlan-id=1 wds-mode=disa
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=
default-authentication=yes default-forwarding=yes defau
default-client-tx-limit=0 hide-ssid=no security-profile
