Is there any way of configuring shared VLAN learning (SVL) on a bridge that has vlan-filtering set to yes?
Doesn’t seem it is possible. Explanation of effects of setting vlan-filtering=yes in bridge manual explicitly states that setting this property changes bridge from SVL to IVL.
What would you like to achieve by running bridge in SVL mode?
Bloody Aussies with their difficult questions, what with crocodiles, sharks, stonefish,octopus, poisonous spiders, snake, drunk koala bears and boxing kangeroos, fires etc. there would be none left… Lets be honest, why would anybody stop and stay in Australia with New Zealand so close at hand. ![]()
Seriously what is the difference between SVL and IVL… if tag stacking was not enough…
Here’s an article for you: https://community.extremenetworks.com/faqs-233202/in-802-1q-what-is-the-difference-between-ivl-and-svl-5815317 . And another one: https://flylib.com/books/en/2.115.1.55/1/
Come back later and write a resumé for us dummies.
It would allow the configuation of asymmetric VLANs as described in Annex F of IEEE Std 802.1Q-2014.
Now you got me intrigued. I can’t find document containing the Annex you mentioned on line, so can you briefly describe how it’s supposed to work?
I was hoping for IVL/SVL for dummies ![]()
A simple example to demonstrate the concept. (This is an example only. It’s not what I’m trying to achieve, so please, no suggestions of other ways in which it might be done.)
Start with a 5-port router: ether1 is the uplink; ether2–ether5 are connected to bridge1, which has a PVID of 1. I want to share a single subnet across 2 VLANs (for no particular reason). Ports ether2 and ether3 are both on VLAN 2; ports ether4 and ether5 are both on VLAN 3.
set 0 pvid=2
set 1 pvid=2
set 2 pvid=3
set 3 pvid=3
/interface bridge vlan
add bridge=bridge vlan-id=1 untagged=ether2,ether3,ether4,ether5
add bridge=bridge vlan-id=2 untagged=bridge
add bridge=bridge vlan-id=3 untagged=bridge
set 0 vlan-filtering=yes
Ports 2 and 3 are isolated from ports 4 and 5, but they all share the subnet configured on the bridge (e.g. 192.168.88.0/24).
This works, but at the expense of flooding. For example, the bridge (on VLAN 1) can’t learn the MAC addresses of the hosts connected to ports 2 and 3 (VLAN 2) and to ports 4 and 5 (VLAN 3), because they are on different VLANs, so it floods traffic to all 4 ports. Shared VLAN learning would fix this.
Hmmm, not sure I follow.
SVL - Single forwarding database for all Vlans
IVL - Forwarding Database for each vlan.
Use IVL when you want same MAC address in each vlan, how does same subnet come into this?
IVL - Forwarding Database for each vlan.Use IVL when you want same MAC address in each vlan, how does same subnet come into this?
VLANs 2 and 3 share the subnet configured on the bridge.
The hosts table shows the MAC addresses for the hosts connected to ports 2 and 3 in VLAN 2 (only) and those connected to ports 4 and 5 in VLAN 3 (only). The MAC address for the bridge is in VLAN 1 (only). If the IP address of the bridge is 192.168.88.1/24 and that of the host connected to port 2 is 192.168.88.2/24, then the bridge can send datagrams to the host, but because the host’s MAC address is not in VLAN 1, they are flooded to ports 2, 3, 4, and 5.
This is a contrived example. Annex F of IEEE Std 802.1Q-2018, which can be downloaded for free, explains the concept much more clearly.
Do you require multiple VLANs on ports, or are you just trying to isolate groups of ports sharing a subnet within a layer 2 network? If so port isolation or bridge horizon may be a solution.
Finally someone (tdw) talking requirements and not fancy acronyms… whadya want kiss on the forehead or chocolate chip cookie?
Single malt is good
Both: ports 2 and 3 on VLAN 2 are isolated from ports 4 and 5 on VLAN 3, but all ports have access to the bridge.
Port isolation is a switch chip feature, so it doesn’t apply to (for example) VPLS interfaces. I can’t see how bridge horizon would help in this example.
Yes, bridge horizon wouldn’t work with groups of ports. How about bridge filters
add name=list1
add name=list2
add interface=ether2 list=list1
add interface=ether3 list=list1
add interface=ether4 list=list2
add interface=ether5 list=list2
/interface bridge filter
add action=drop chain=forward in-interface-list=list1 out-interface-list=list2
add action=drop chain=forward in-interface-list=list2 out-interface-list=list1
