sharing bw with pcq substreams and queue trees
Hi, I am working on understanding queue function and implementation, and after watching
http://www.tiktube.com/?video=mJeK3iHGhLKLIKImpnCsFrHvnlIomlpG= (QOS workshop by Janis Megis)
I am unable to experience what is being described at 68:50-> 69:00.
If I understand correctly, Janis is explaining that with pcq, if a person is active on the network, there is automatically a substream reserved for them which at best is equal to the max-limit divided by number of pcq queues.
I am implementing these queues with queue trees and not simple queues, and my tests show that there is no allotment of unused bandwidth, but that it is divided equally among users only when real traffic flows reach the max-limit value.
Have the rules changed? Can someone clarify this behavior?
Thanks!
ros v5.23
I’ve found the same behavior… MaxLimit is not used at the tree branch. Have you found an explanation or solution?
thanks
to divide traffic equally, you need to know the bandwidth. you set it in ‘Max-Limit’ value
