Shoretel Switch send a RST and unable to communicate to Shoretel Server
Hello All,
We had a MPLS connectivity between our HQ and branch, we have recently migrated to IPSec VPN and i have enabled all ports between the HQ Soretel server and the branch Office. We can do a ping and access the Shoretel Branch swithc but Swith fails to Pair up as its sending RST packets back to HQ server.
Will SHoretel works fine in IPsec ? do i need to do anything to avoid this issue.
Shorele guys says there is a network issue Port 5452 seems Filtered intermittently. I have checked the config with Cisco Support, they verified and confirmed ports open and nothing found in packet capture.
can any one suggest over my case ? below are the Logs
tmsncc log shows hq cannot communicate to this switch
00:00:12.321 ( 5072: 6528) cco_cmd: clnt_call error: status= 3 (RPC_CANTSEND)
00:00:12.321 ( 5072: 6528) ncc_connect_setup: → -20 (RPC_ERROR)
00:00:12.321 ( 5072: 6528) ncc_connect_to_switch: “10.104.6.7”, 5452
00:00:12.327 ( 5072: 6528) 9, (19.47.5900.0) “10.104.6.7”, “00-10-49-3D-2D-5B”, 25(SG4-30) Flash, “en-US”, (1.1.3.27),“3 d + 08:12:45”,0
00:00:12.327 ( 5072: 6528) ncc_event_connect (2018/06/11 07:00:12.327, +7)
00:00:22.328 ( 5072: 6528) readtcp wfmo timeout
00:00:22.328 ( 5072: 6528) sw_cmd: clnt_call error: status= 5 (RPC_TIMEDOUT)
00:00:22.328 ( 5072: 6528) nec_event_connect_ex: → -20 (RPC_ERROR)
00:00:26.314 ( 5072: 6528) ncc_connect_to_switch: “10.104.6.7”, 5452
since the ip address changed to a different network, this may be firewall issue. There are no other switches that the server is not able to connect to only this switch.
tmsncc keyword search “ncc_connect_to_switch”
  1. pcap filter used
    udp.port eq 5440 and ip.addr==10.104.6.7
    results= hq server does communicate to swtich and switch responds udp port 5440 ( location service ) port
  2. pcap filter used
    tcp.port eq 5452 and ip.addr==10.104.6.7
    results=you will see the hq server communicate with the switch but then you will see the switch send a RST ( connection reset ) back to the hq server.
  3. pcap filter used to confirm udp port 5452 comm between hq and switch
    tcp.analysis.retransmission
    results= hq tries to communicate with switch on udp port 5452 , switch does not respond. hence lost communications with the switch via director.
  4. pcap filter used to confirm connection reset
    tcp.flags.reset==1
    results= switch sends a connection reset to hq server. there are other connection resets shown with this filter to other ips but do not look like they belong to pbx system
