I need to bridge only about 100 ft / 30m between two buildings, but would like a high-bandwidth link between the two. Would the SXT 5 ac 28 deg be a good option for this? In particular, will I be able to tune the power low enough for such short distance? Thanks.
I recently set up a 35M link with 2x SXT5AC’s. With the output power set to the minimum allowed (-30) I was able to get a rx signal around -44. So not too bad.
Hope that helps.
