I need to build a short range (50m) bridge.
The problem is that there are trees between two points - and direct visibility is limited by leafs.
2,4 GHz band is highly occupied so the only choice would be 5 or 60GHz.
I wonder whether Wireless Wire Cube Pro would work fine (60GHz) in this situation, or should I aim SXT SA5 ac instead?
The common reports about 60 GHz Is that you need clear line of view, even some fog or medium heavy rain can compromise the link, tree leaves are a no-no.
A Cube in such a setup will likely continuosly fall back to the (much slower) 5 GHz.
Besides the SXT SA5 AC, which I believe is intended for much longer links, you probably could also consider the SXTsq 5 AC (don’t you love how Mikrotik manages to choose such distintive names?).
