I hate seeing my transfer throughput been stuck at 130mbits (or 270mbits) only because Mikrotik insist not to implement the short GI option (found on any other wifi device). And before some MT folks make mention that the “auto” setting does the job, it doesn’t, even when client is just a few meters away from the router in a clean from interference environment with signal strength better than -50dBm and CCQ 100%.
Please put in this damn setting and let users decide whether they make use of it or not.
PS: People buy Mikrotiks to have full control over their setups. If we liked auto-settings we’d stick with some cheapo of the self routers (which btw support short GI).
if you are using Nv2 then short guard interval is not supported yet in nv2 protocol.
For the regular 802.11 protocol it should go up to that if you have good link.
It should, but mostly it doesn’t. Unless of course -52dBm, 100% CCQ in clean from interference area cannot be considered as good link. At the same time, under exactly the same conditions and distances other home routers (short GI’ed) constantly achieve maximum throughput.
And btw, I really don’t understand why is so hard for you to include this easy to implement and protocol standard third option. If “Auto” and “Long” values already exist in ROS, why not the “Short” one that already being supported by virtually all existing 802.11 devices and AP OSes?
I agree with you Athan, but since I asked for this option more than a yaer ago when v4.2 was released see: http://forum.mikrotik.com/t/v4-2-released/32543/1 and it’s still not available I think that they DON’T CARE about it or about us who ask for it.
Shame on you MT.
Yeah, supported in …theory!
Same time ROS “auto” setting fail to enable 400ms GI other routers with manually forced short GI work at max throughout. And that’s what matters dear normis.
And BTW, if you MT folks really like “auto” setting that much then give us the “short” option and keep “auto” too. I’m OK with that!
It’s enabled when conditions are good to use it. If you will force it under bad conditions, nothing good will come out of it. Don’t expect that this setting is some magic speed-boost button.
I don’t know normis what the signal, s/n or ccq auto-setting thresholds really are, but all other routers I have here work at max throughput same time Mikrotik is stuck at 130/270mbits. All with same clients, same distance and using the same antennas.
As for “magic speed-boost buttons”, we all know what GI really is (or isn’t). What I’m asking you is to give user access to a protocol-standard option and the freedom to decide whether to use it or not. If Cisco, Netgear, D-Link, DDWRT, OpenWRT and Atheros drivers across all OSes give this option to users then you have to do that too. So please, keep the auto and long setting and implement the missing short one.
Never said that the “any” setting doesn’t work under ideal conditions. I’ve seen such peaks putting clients next to Mikrotik router.
What I highly doubt is the effectiveness of the “any” setting thresholds under great but less than ideal receiving conditions. I hate repeating myself, but when a dozen of different routers with short GI enabled keeping max metered performance same time Mikrotik’s limits throughout to 130/270 mbits, then there is a problem.
And why all this? Because of MT people stubborn refusal to include in their software front-end the third value of an already existent and widely used driver setting. They could have done this in less time than posting a single answer here in forum.
