Short link(around 30m) - hardware choice
Hello guys, I’m new to MikroTik and I need to do a short p2p bridge link between my network and photo printer inside small production hall. The distance is around 30meters. I need real bandwidth around 200Mbps. Which hardware i should use for short good performance links? Thanks for any advice.
See this. http://routerboard.com/RBSXTG-5HPacD-HG
Hi, see my post below discussing a similar length link. That was using 2x SXT 5 ac’s (http://routerboard.com/RBSXTG-5HPacD).
http://forum.mikrotik.com/t/short-distance-high-bandwidth-p2p-hardware/89569/2
For 30 meters? That will do 3000 meters or more…
Would 30 meters not work with just about any WiFi equipment for indoor use you can find?
30 m ?? You could invest in some radios… but for that distance I would go for full duplex 1gbps “link” for less than $100 by using cat 6 self supporting ethernet cable - if that is possible in this case.
