Short Preamble problem
I am using AR5413 cards for wlan1/2/3 all part of the same WDS. wlan 1/2 are backhaul links and wlan 3 is for clients. I have tx and ack timeout set to default for wlan 3 but all the clients that register have -53/-61/-65 and excellent connections but it says -SP next to them and there tx/rx rates are 1mbp-SP/18 and what not. I thought it might be interference so I stuck wlan3 on a different bridge and selected a less noisy channel but I am experiencing exactly the same problem. What should I check to remedy this transmit rate low issue? Below is the original config.
0 R ;;; To BLDG1 - 00:0C:42:1B:39:00
name=“wlan1” mtu=1500 mac-address=00:0C:42:1B:39:C7 arp=enabled
interface-type=Atheros AR5413 mode=station-wds ssid=“ssid-backhaul”
frequency=2472 band=2.4ghz-onlyg scan-list=default antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=yes
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=Enabled
compression=no
1 R ;;; To BLDG2
name=“wlan2” mtu=1500 mac-address=00:0C:42:1B:39:01 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid=“ssid-backhaul”
compression=no
2 R ;;; Omni For clients
name=“wlan3” mtu=1500 mac-address=00:0C:42:1F:2D:02 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid=“ssid-123”
wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
compression=no
