Been watching some discussions about various bonding or other techniques to get some pretty decent backhauls created.
I want to start on a really short link. <1 mile
I am looking specific suggestions for this could with a hardware list to put it together right away. Dont know if it matters but will need to allow for a redundant path to a second tower with similar bandwidth capabilities.
Any specific list of all the Pieces would be most helpful!!
i didn’t really like nstreme dual for this type of situation so i bonded 3 wireless links together to get a cumulitive amount of 160megabits. i’m using 6 rb333 boards for the wireless bridges, 6 r52 wireless cards, 2 rb600 boards to do the bonding. i’m running 3.x on all the units, nstreme turned on, csma disabled, 40mhz bands on the wireless for max throughput. for antennas i’m using hyperlink 5.4 grids http://www.hyperlinktech.com/productfamily.aspx?id=109 . hope this helps.
I finally got a chance to try this today. Two 433 boards each with one R52 card. connected indoors.
Tried the basic way I know how to connect these. AP Bridge and WDS Slave. in 40Mhz channel got 22Mbit only throughput (about the same upload and download).
Tried lots of other options, but never got past this 22 mbit.
