Hi all! I’ve been a happy user of Mikrotik routers for a while - but I’ve never used Mikrotik wireless. Just didn’t need it. Now…but the deep range of products available leaves me confused - I’m not sure where to start.
I have a customer that will need to support some wireless cameras. I don’t know make/model yet - nor even network spec - but I’m going to assume 802.11n on 2.4g is my baseline. If the ideal Mikrotik also offers dual-band and/or 802.11ac then that’s a bonus - not a requirement.
My first requirement is stability. I shouldn’t have to worry about that since we’re talking Mikrotik.
The second requirement is high temperature tolerance (this is for Las Vegas, Nevada). The products I’ve looked at are all rated to 70C so I should be good.
The third requirement is to “play nice” with the existing premise equipment - which is a blend of existing consumer AP’s (I’ve identified D-Link and Apple) connected to a switch, all having the same SSID. I didn’t design it - I’m just trying to work with it. I believe the “controller” is a Sonicwall firewall/router.
The intended installation will be atop a 6’ pole. The camera locations will be within 100’, and within a 90 degree field of view from the AP.
At the moment, the products I am considering include:
“Groove” RBGrooveA-52HPn with omni antenna (possibly an aftermarket antenna as I’ve heard negative comments regarding the included model)
“Metal” RBMetal2SHPn (again, possibly with a different antenna)
Using Groove/Metal would also allow me to place the radio inside a fan-cooled enclosure (I’m paranoid about equipment burning out) but I’m hoping the 70C temperature rating is real.
If it turns out that 5GHz is the requirement then:
“NetBox” RB911G-5HPacD-NB
“mANTBox” RB921GS-5HPacD-15S
“NetMETAL” RB922UAGS-5HPacD-NM
I thought the SXT series would be overkill. Anyway - can anyone give me some guidance here? I just want an install-and-forget AP solution, and as my intro indicates the networking demands are going to be minimal.
