Should I bypass tunnels connections in mangle ?
I have a gre tunnel up and running
Since I started to insert some mangle rules for routing mark purpose I’ve seen no more packets flowing through tunnel
I have inserted first an Accept rule with local Lan as source and remote Lan as destination but with no results.
So I had to insert an Accept rule before the marking ones with local Lan as source and remote tunnel endpoint as destination to restore tunnel functionality
Is this the correct practice ??
Thank you
