Should I click to upgrade or not?
Hi there,
Just now I checked my RouterOS for any updates and this was what I found. My existing version is 6.49.18 (upgraded earlier in Feb) and the latest available update is also 6.49.18, and there is a “Download & Install” option.
So I am a bit confused, is this a bug of some sort? Are both versions the same thing? Can I just stick to my existing installation?
Thanks…Lee
on the 6.49.18 topic edpa wrote:
No. Yes and No (build time differs as @itimo01 mentioned). Yes.
