should i enable SNMP on my Mikrotik Hex
Hello All,
Currently our Mikrotik Hex doesn’t have SNMP enabled, I did not disable it or anything of the sort, just curious if i was to enable it what benefits would it serve our network?
Thank You.
Regards.
Graham
Most probably you will notice no change at all.
