Hi, i use Winbox and “IP->Firewall->Connections ” tool it’s very useful for me.
At the bottom of this window I can see: “2057 items out of 15000 | Max Entries: 524288 ”
How can i see the others connections? or show only marked connections that i want? (ie: all p2p connections)
Cristian
normis
September 18, 2009, 7:46am
3
you can use torch to see only what you need. in the connections window you can’t see everything, because it takes too much resources.
Chupaka
September 18, 2009, 8:27am
4
you can export all to file via CLI
Thanks for alternatives!!
Chupaka
September 18, 2009, 2:52pm
6
by the way, in API, ‘/ip/firewall/connection/print =follow=1’ don’t receive new entries, although it don’t send ‘!done’ and tries to listen for new ones… will that be fixed? =)
