show ip route x.x.x.x
Is it possible to do “show ip route x.x.x.x”?
/ip route print where dst-address=“x.x.x.x/x”
With the caveat that it’s going to look EXACTLY for that prefix. It doesn’t search the routing table for a route, it matches entries as strings. If you have a route for 192.168.0.0/24 and 192.168.0.0/25 then searching for 192.168.0.10 won’t bring up either one.
There is no direct equivalent to ‘sh ip ro’. You can sort of fudge it with regex searches, but you might not catch supernets, and will never catch the default route.
Yes, it is correct that “ip route print where dst=x.x.x.x” can not look up for supernet.
Is there any way to work around to find supernet or exit interface?
/ip route print where 192.0.2.10 in dst-address
Works in 4.9 and up for me.
+5 for solving my biggest goddamn annoyance with RouterOS.
I owe you a beer.
From the PM for Karma. Thank you. Times a thousand. Never knew.
I am using ROS4.13 but it doesn’t work for me as below:
/ip route print where dst-address=192.168.86.1
will not work because, route in routing table is 192.168.86.0/24 which is not equal to 192.168.86.1
If you want to see what routes can be used to resolve an address use the command that blake mentioned
/ip route print where 192.168.86.1 in dst-address
You’re welcome. I recently found that little gem while trying to help a user on a mailing list with this exact problem.
It was a little ‘hard’ to find because the in keyword doesn’t syntax highlight as it does in ‘where dst-address in x.x.x.x’ leading you to believe it would not be a valid command.
I have CCR1009-8G-1S-1S+ with RouterOS 6.36.2.
After I configure a full BGP /ip route print where 8.8.8.8 in dst-address it take several minutes to get a result. Should I use another command to check which path is being used to reach 8.8.8.8?
Or isn’t supposed to run full bgp on a CCR1009-8G-1S-1S+ ?
If I do this kind of query (show ip route 8.8.8.8) in other router, also with full BGP, I get the answer in a few seconds.
Thanks,
David Costa
I know it’s not the same, but…
/ip route check 8.8.8.8
Will show you the exit interface; RouterOS Tools > traceroute will show the path along with latencies to all involved hosts.
BGP will be Multi-Core optimized on ROS 7.
/ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
0 ADS dst-address=0.0.0.0/0 gateway=192.168.168.1 gateway-status=192.168.168.1 reachable via e1-gateway distance=0 scope=30 target-scope=10
vrf-interface=e1-gateway
1 ADC dst-address=172.16.16.0/21 pref-src=172.16.16.1 gateway=br1 gateway-status=br1 reachable distance=0 scope=10
2 DC dst-address=172.16.254.0/29 pref-src=172.16.254.1 gateway=e5 gateway-status=e5 unreachable distance=255 scope=10
3 ADC dst-address=192.168.168.0/29 pref-src=192.168.168.3 gateway=e1-gateway gateway-status=e1-gateway reachable distance=0 scope=10
