Hello
I have a problem with my router, because I lost my password, but luckily I had saved in winbox. I’d like to know if there is not a menu winbox that allows to see the password ?.
open with an editor “Addresses.cdb” file. if you have not password protected winbox, you will see the passwords
Where I will find this file
open ‘New Terminal’ then type ‘export’
http://wiki.mikrotik.com/wiki/Manual:Configuration_Management#Exporting_Configuration
Its seems simple to solve.
Just change your password using system/users select your user by using double-click and then password.
if its not in winbox folder search all your computer. i am talking about windows installations!
Suggestion by gilliardmelo is much better. Do not mess with the database files.
