Show user ip on lan side
Hi all,
I have a Mikrotik router and a Synology nas.
Before I got the MK router I was able to see the IP of users logged into my NAS.
Now when users log in to my NAS from outside my lan I can only see the router local ip address.
I want to be able to see the users real internet IP in the logfile of my NAS.
I don’t know what that option is called or how to fix it.
Thank you very much..
Br. Simon
Post result of:
/ip firewall export hide-sensitive
if you used dst-nat for your NAS, you should see the external IP when they going through the fireware and the NAS device should see it too.
Most likely there’s just:
instead of proper:
add action=masquerade chain=srcnat out-interface=<WAN>
Like this is even more precise
add action=masquerade chain=srcnat out-interface=<WAN> src-address-type=!local
add action=masquerade chain=srcnat out-interface= src-address-type=!local
Thank you very much. The last one here worked perfect! You are GREAT!
