Shrew Soft IPSEC Client
I’ve recently setup my MT router using the wiki article - http://wiki.mikrotik.com/wiki/IPSEC_between_Mikrotik_router_and_a_Shrew_client. I can successfully connect to the router from a remote location, but am unable to ping/browse or access anything on the remote LAN. The only change I made to my config was with the peer address. I used 0.0.0.0/0 since I want to use a “Road Warrior” style remote access to my LAN.
What am I overlooking in my configuration?
 /ip ipsec installed-sa> /ip ipsec peer pr
Flags: X - disabled
 0   address=0.0.0.0/0 passive=no port=500 auth-method=pre-shared-key
     secret="abc123" generate-policy=port-override exchange-mode=main
     send-initial-contact=yes nat-traversal=no proposal-check=obey
     hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d
     lifebytes=0 dpd-interval=2m dpd-maximum-failures=5
The IPSEC parameters all indicate the tunnel is established, and I think my input and forward rules are correct.
/ip ipsec remote-peers pr
0 local-address=64.xx.yy.zz remote-address=216.64.190.250 state=established
   side=responder established=34m11s
/ip ipsec installed-sa> pr
Flags: A - AH, E - ESP, P - pfs
 0 E  spi=0x1C839AE src-address=216.64.190.250 dst-address=64.xx.yy.zz
      auth-algorithm=md5 enc-algorithm=3des replay=4 state=mature
      auth-key="db8d814aa09348ce546c4efcf1da3d71"
      enc-key="f9cf2e97163cb57054522982605326bebcbc8043136581dd"
      add-lifetime=48m/1h
 1 E  spi=0x2B4AA3B src-address=64.xx.yy.zz dst-address=216.64.190.250
      auth-key="7a294f4440c3b5533f2bd5e142db9404"
      enc-key="088b6d9e72a5d16a1e5ad6ac9827aa21d6bea41195c42507"
      add-lifetime=48m/1h
 2 E  spi=0x823C3B8 src-address=64.xx.yy.zz dst-address=216.64.190.250
      auth-key="033521da1bde6e29a60233deda3f3ad0"
      enc-key="da820729d265146f7d0555e698c8d761557401f48c5ab574"
      add-lifetime=48m/1h
 3 E  spi=0xB19AA23 src-address=216.64.190.250 dst-address=64.xx.yy.zz
      auth-key="d07515a8713a6a3242cf653f745bf0b0"
      enc-key="3dab4fdbbdcb00c82d605e46b244bea0dad109f9c35e7acc"
Disabled items have been removed for brevity.
/interface bridge pr
0  R name="lanbridge" mtu=1500 l2mtu=1600 arp=proxy-arp mac-address=00:0C:42:06:70:83 protocol-mode=none priority=0x8000
      auto-mac=no admin-mac=00:0C:42:06:70:83 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
/interface bridge port pr
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE                                    BRIDGE                                    PRIORITY  PATH-COST    HORIZON
 0    e1-lan                                       lanbridge                                     0x80         10       none
 1 I  wlan1                                        lanbridge                                     0x80         10       none
/ip firewall filter pr
 0   chain=forward action=accept in-interface=lanbridge out-interface=lanbridge
 2   ;;; allow established connections
     chain=forward action=accept connection-state=established
 3   ;;; allow related connections
     chain=forward action=accept connection-state=related
 4   ;;; Allow VPN traffic (protected to protected)
     chain=forward action=accept src-address-list=ProtectedIPs dst-address-list=ProtectedIPs
 5   ;;; Disallow outbound to private IPs
     chain=forward action=reject reject-with=icmp-network-unreachable dst-address-list=ProtectedIPs out-interface=e3-wan
 6   ;;; Disallow inbound to private IPs
     chain=forward action=drop dst-address-list=ProtectedIPs in-interface=e3-wan
 7   ;;; Allow filter rules to deny access
     chain=forward action=jump jump-target=InternetBlacklist in-interface=lanbridge out-interface=e3-wan
 9   ;;; Allow Internet access if blacklist did not stop it
     chain=forward action=accept in-interface=lanbridge out-interface=e3-wan
11   ;;; log everything else
     chain=forward action=log log-prefix=""
12   ;;; drop everything else
     chain=forward action=reject reject-with=icmp-admin-prohibited
13   ;;; Invalid Connections - sliently drop
     chain=input action=drop connection-state=invalid
14   ;;; Accept all from internal LAN
     chain=input action=accept in-interface=lanbridge
16   ;;; Established Connections
     chain=input action=accept connection-state=established
17   ;;; Related Connections
     chain=input action=accept connection-state=related
19   ;;; Allow IPSEC
     chain=input action=accept protocol=ipsec-esp
20   chain=input action=accept protocol=ipsec-ah
21   chain=input action=accept protocol=udp dst-port=500
27   ;;; Allow SSH
     chain=input action=accept protocol=tcp dst-port=22
28   ;;; Allow Winbox
     chain=input action=accept protocol=tcp dst-port=8291
29   ;;; Allow limited pings
     chain=input action=accept protocol=icmp limit=20/5s,2
30   ;;; Log and drop all else
     chain=input action=log log-prefix="INDROP"
45   ;;; Record high volume SMTP sources
     chain=InternetBlacklist action=add-src-to-address-list protocol=tcp address-list=listBigSenders
     address-list-timeout=0s dst-port=25 connection-limit=10,32
 /ip firewall> address-list pr
Flags: X - disabled, D - dynamic
 #   LIST        ADDRESS
 0   ;;; Static Public IP assigned by ISP
     PublicIP        64.xx.yy.zz
 1   ProtectedIPs        172.16.0.0/12
 2   ProtectedIPs        192.168.0.0/16
 3   ProtectedIPs        10.0.0.0/8
 4   listSBPublics        64.xx.yy.0/20
Did you success on this..?
Having same issue, unable to pass traffic from LAN to WAN via VPN.
Best regards
