shutting down interfaces at a specific time
Hello everybody,
would it be possible to write a script that shutsdown an interface, lets say between 2200h and 0600h everyday?
If yes does somebody out there have a code snippet i can use to get started?
Best regards
1001001
If You want to run only one command on specific time, you don’t need a script, you can just add scheduler:
to disable interface at 22:00
/system scheduler add start-time=22:00:00 on-event={:interface ethernet disable ether5}
second scheduler to enable interface at 6:00
/system scheduler add start-time=06:00:00 on-event={:interface ethernet enable ether5}
Thanks for your answer.
What if we had to do this at different times on different days?
Best regards
1001001
you have to make schedules that start for example 26-09-2015 “saturday” and repeat “weekly” so it runs every week same day
