I am trying to get this Sierra Wireless MC8705 3G module to work but I cannot get the routerboard (411UAHR) to talk to it apart from recognizing it as a USB device under resources.
I have tried the following commands with no response…
/system serial-terminal usb2 channel=0
/system serial-terminal usb2 channel=1
/system serial-terminal usb2 channel=2
/system serial-terminal usb2 channel=3
/system serial-terminal usb2 channel=4
(@Baud 9600 and then as auto)
Under System/Resources/USB, I have listed:
1:1 RB400 OHCI
2:1 RB400 EHCI
2:2 MC8705
Under ports I have listed:
Serial0
usb2
Has anyone successfully got ones of these to work, or do I have to purchase an older model module?
What RouterOS version you are using?
check maybe the card is recognized at LTE card - check the interface lte menu.
If you want to use the old style ppp connection for this card use this command and do a reboot the router after that:
/port firmware set ignore-directip-modem=yes
