Sierra Wireless MC8790 GPS not working on RouterOS v5.4
I have a RB411UAHR with routeros v5.4, with the gps package installed. I have installed an minipci-e Sierra wireless MC8790, the 3G connection is working fine, but i can’t get the GPS coordinates from the terminal.
I have enabled the GPS with the command
/system gps set enabled=yes port=usb2
and running the
/system gps print
it outputs the following:
[admin@MikroTik] > /system gps print
          enabled: yes
          port: usb2
          channel: 2
          set-system-time: no
[admin@MikroTik] >
But the
/system gps monitor
output null values.
The command at!gpsloc? returns:
at!gpsloc?
Not Available
OK
Same with my card, did you get the Problem fixed?
