signal 100% but ????
hi , All
i have Rb 433ah,xr2,
and every thing being OK ,
but I Have a Problem with Airlive access point (400Mwat About 26 DBM )
connected with Xr2 as WDS Repeater.
although Signal being good !!!
signal 22-26 Db .Tx/Rx CCQ 85% -100% P throughput not less Than 5200 kbps
i think that is good
But Her is The Problem
it disconnected Every Minute 3 Or 4 Times .
is there any solution to this Problem .
A general rule if you MUST use wds is to ensure you’re using the same brand at either end.
Hardware from different manufacturers isn’t guaranteed to function optimally in a wds mix as far as my experience goes.
I suggest you replace that Airlive unit with a routerboard.
