signal issues
i have got my systems all set up but now having singal issues my wireless card 1 show 59 % from near by scan of the singal but my wifi card 2 shows 70% pictale is fine coaxil is fine and the sector anntenna is brandnew and fine aswell what could be the issue?
signal is not shown in % but in dB where smaller number is better. ie signal “-56” is better than signal “-70” (which is pretty bad).
Try different channel or freq. Some channels have more noise than other.
yh i think thts why but one of my main boards has locked down i backed it bck to a back up which i don t know the password i can t even reset it i dunno what to do any suggestions.?
Look here
http://wiki.mikrotik.com/wiki/MikroTik_Password_Recovery
i have tried that it does not reset ?
You should hold it untill the router beeps.
Sotimes i do it twice just to be certian.
I cant remember if the routerboard beeps when you power it on. But you sjould wait untill the routerboard has booted up. It usualy takes 30 seconds depending on the rules.
when booting i hold the metal peace on the reset point for 10 mins still no reset?
would female to femal connector do to reset the boards called d connector
try something else such as a coin or wire..
Maybe you should return it as it might be faulty
tried all nuting guess only the cable can help now
