Signal levels from "remote" wireless
Lets say I have a bunch of grooves in a network, and I manage all the queues with bridge mode
Is there a way to check signal levels within the routerboard that manages the queues without login into each groove?
Maybe is super simple and noob level question, but i really cant find how.
On the main access point registration you can see both tx and rx signals.
maybe my english is rusty?
i want to check the signals without entering each groove separately, can i add the registration tab somehow to my main routerboard?
If you check the “TX” signal in your AP, you can see how good the clients can see the AP. This is visible in the Registration table on the AP. You don’t have to log into each client to see their signal. Just look at the TX value in your AP menu “registration table”
Wow, my english must be really really bad, and if you are answering what i’m asking, I might go to the doctor.
Lets do it again
I have a Mikrotik Routerboard 3011
Behind that I have 10+ Grooves installed, on bridge mode, so I route everything with my 3011, and I dont want to log on every single one of them to check the signal levels
Is there a way to check the signal levels on the routerboard 3011?
My registration tab on 3011 shows NOTHING (as it should), is there anywhere I can see it, or any configuration to setup and see it WITHIN my 3011?
Crap! :stuck_out_tongue:
Use capsman.
