Signal range
in Connect List v.3 now has a signal range option, the default is -120..120
What does this actually mean?
If I want to prevent APs associating at less than -90dBm what values should I use - would -120..90 be correct?
use this:
-90..120
so it works correctly :-))
Regards
Lutz
I tried -90.120, -80.120, even -70.120 - they still register.
Are you shure that the Connect-List will be used? Default-Authenticate = Off?
This works fine in all our installations.
Regards
Lutz
