signal strenght access-list
with the following rule:
0 mac-address=00:00:00:00:00:00 interface=wlan2 signal-range=-80.-50 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key=“” private-pre-shared-key=“”
I have one client with signal -84 still able to connect even if this rule is enabled.
User is authenticated via PPPoE server, OS is 3.0 beta4
Any suggestion ??
Thanks in advance,
.:[CRT]:.
Solved.
Just disabled then enabled wlan2 and interface goes up with new access list rule :slight_smile:
.:[CRT]:.
Make sure you have set ‘default-authentication=no’ at the AP.
I have tried on my AP and specify ‘signal-range=-70.120’, client with signal -77 has been disconnected after default-authentication has been configured to ‘no’.
