I have ask a new broadband connection in my local area ISP. They are giving internet access throgh wifi antenna. Their enginner came and install the antenna model Routherboard SXT5 LITE. But when they have checked the signal strength of their tower it is showing greater than -80 for all of their 4 channels. Their enginner is now telling signal strength should be below -70 or -75 to connect.
I could not understand why they are saying like that. If signal strength is showing -85 or -90 then what is wrong here??? Could you guide me in this regard.
-85 or -90 means weak signal
-75 or -70 is normal signal
-65 or -60 is great signal
-55 is excellent
If you have such low signal, it means you need to align the antenna, adjust the angle and position it higher above ground, so that ISP tower is in good visibility, and pointed correctly.
Their engineer is right to tell you that this installation is not good. I assume you ask your question here because they deny to do the installation for you.
If this was me I would say the same. With this signal you will have a problem with the connection and you will call them with problems and they will not be able to do anything to fix them.
Thank you all! After little bit alignment now i am able to achieve signla level 72-78 and got connected to ess. Now i can acess internet without problem.
