Signal strenght tool !??
Hi, I have ubiquiti antennas and mikrotik devices for links .
  • Ubiquiti RocketDish 34dbi 5GHz + RB433+ R52Hn on two points, distance 15 km !
  • need PC program for antenna alignment !!!
Radio Mobile, Winbox, Google Earth
Need tutorial with winbox !
Go on wiki Mikrotik.
Though I didn’t exactly understood what do you want to do!
You want to find out how much theoritical signal you will get from one place to the other?
You need to see the signal while working the link to align it?
I need to see the signal while working the link to align it !!!
To ajust antennas in to the best pozition to get maximum best signal !!!
Ahhhh…you can do it via winbox > wireless
or with any explorer (internet - firefox) loging into your account and > wireless again.
