Dear Mikrotik Gurus
I provide internet to customers via pppoe server.
I have a RB433 with Atheros AR5413 card on it, and the lan port is connected to the pppoe server.The Wlan card is set to 2GHz B/G mode , WDS static with Ignore SSID checked. The clients are working fine, signal strength is good as well as CCQ and TX/RX.
Later I installed RB751 that has Atheros 11N on it. Same setting are made, signal strength are good, but CCQ and TX/RX keep going up and down, and the users routers keep going in and out of the pppoe server, eventhough cliens are connected to the RB751.
How I can get stable CCQ and TX/RX on RB751 and keep users connected to pppoe server?
Thank you
