I have a point to point connection that has decent signal to noise (20) while the opposite side of the connection is hovering around 1 and even dipping into the negatives. I was under the impression that the signal to noise would be the same on both sides but I guess this isn’t the case. What would this indicate? Bad radio on the side with low signal to noise? The ping between the 2 connections are into the hundreds where normally it would be single digit. Any help would be highly appreciated
well that was simple. Turned out the coax came loose
Hope this helps someone in the future. I know a lot of times its a pain to get to the mikrotiks ![]()
