We have made a significant improvement for 60 GHz wireless (Wireless Wire and wAP 60G) configurations in the latest 6.42rc version release - increased supported distance for wAP 60G to 200+ meters.
Those of you who are willing to test rc versions on your test network, please upgrade to the latest version, test the performance and report to support@mikrotik.com with the results. Your effort and feedback will be highly appreciated.
Please note that rc versions are released strictly for testing purposes and should not be used on crucial network devices.
But we are curious souls who would like to Know some details!
Now seriously, I have spammed support with some tests I have done in my link, which is a short one. Stability has gone down with rc49. With rc30 it was rock
solid, as it is with 6.41.3.
The changes I noticed are, higher TX power? (Assuming tx-sector is an indication of TX power)
I installed rc49 on a few of our >100m links (PtP and PtMP) and neither MCS or Signal Quality have changed. Throughput seems better, though, as running a traffic generator over our longest link (160m?) nets a solid 500Mbps full-duplex with little fluctuation. Used to be all over the place. Seeing a lot more link downs, too, but that might be due to rain we’ve been having. Should we be seeing better MCS and/or Quality readings? What exactly is being improved?
Just a heads up, I had an issue with 6.42rc56 on a multipoint (ap-bridge) AP. Interfaces weren’t showing up and the station wasn’t connecting. I switched to bridge mode and everything worked again. Really digging the rssi and tx-sector-info, but I don’t think it’s ready for ap-bridge mode yet.
The perfect product for the 60Ghz, would be a point-to-multipoint solution, clearly with high gain CPE antennas for distances up to max 1km.
Possibility to connect up to 50/60 customers on a single cell
Channels smaller than the 2000Mhz (1000Mhz or 500Mhz)
TxPower increased to 20dB
A integrated failover 5ghz radio could be failover when primary 60Ghz fail due to rain
With this solution provider wisp can delivery 100/200/500 Mbps to customers and fight vdsl fttc/ftth of cable isp
Lupin you are right I think we need a solutions like ignitenet with 5 ghz backup to have a killer product to use in PtMP scenario to max 700m I hope to see it soon it’s not an hard job make it
I’m kinda keen to see some more helpful SNMP OIDs soon - as it would be really useful to see how the link behaves in bad weather. e.g. coding scheme, and RX and Tx sig strength?
You can do it that now just run script in scheduler read RSSI or signal and disable or enable port in bridge or whatever you wont it is possible now with script run in scheduler.
